Drop Drywall Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 05:25 PM   #1
We are starting to think about finishing our basement. We want to do a drywall ceiling; however we want to drop it to cover all the HVAC stuff. We have 9 foot between the bottom of the joists and the floor so height isn't an issue. Are we dreaming, or is it possible to lower the drywall ceiling?
JasonS is offline   Reply With Quote
Old 09-26-2009, 05:52 PM   #2
Drywall contractor
Rewards Points: 1,070
Absolutely! You can frame it with wood or metal studs. There is even a grid system for attaching drywall to (available at an drywall and/or acoustical supply yard. None of the above is really DIY "friendly" unless you're pretty experienced, but definitely can be done....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-26-2009, 10:46 PM   #3
Remodeler
MinConst's Avatar
Keep your nice ceiling height and just box in around the duct work. Allot less framing and you will have a nice high ceiling everywhere else. Frame around the duct work with 2x3s or 2x4 fastened to the existing floor joists.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-27-2009, 02:57 PM   #4
Thanks for the advice. My wife and I were looking last night, and I think it won't be too bad if it's lower in two different areas. Besides, I think we're going to frame everything ourselves, and hire out the drywall work, but I think we'd hire out the entire thing if we dropped the ceiling. We need to save wherever we can.
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 04:33 PM
drywall for the ceiling genner Drywall & Plaster 8 01-11-2009 10:29 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Plaster Ceiling and drywall dprasan Remodeling 6 02-06-2008 12:34 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
