Drill For Mixing Mud - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 06:47 AM   #16
DIY staff
Rewards Points: 7,174
I smoked a lot of drills before I finally spent the big bucks on the Milwaukee.
Killed a Black and Decker in 4 hours once---
Old 10-14-2011, 01:52 PM   #17
Any drill with high torque and lower rpms should work fine. Most variable speed drills were not built for mixing. They will work but you can burn them up pretty easily.
yeag6154 is offline   Reply With Quote
Old 10-14-2011, 04:05 PM   #18
Drywall contractor
Rewards Points: 1,070
Gotta agree that the variables aren't as stout. The old Craftsman I referred to was bought somewhere in the 1980/81 time frame, I'm guessing, at a surplus store (rebuilt) for I think around $45.00 or so. It has literally mixed thousands of cans of ready mix and many bags of DuraBond (the main reason I got the variable). Had it rebuilt once (mainly as "preventative maintenance), probably in early '90 or so, and it still works. (I have to admit you could smell a bit of a "burning" smell at times after mixing several buckets non-stop, but it never quit.) I retired it because I don't mix that many buckets at a time any more.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-17-2011, 12:25 AM   #19
I had the same issue when I remodelled my kitchen. I bought a cheap variable speed corded power drill just for mixing thinset. The drill lasted until the second last batch. Now that I am remodelling my bathroom, I purchased a 1/2" low speed, high torque drill from Harbor Frieght for less than 50 clams. I mixed up one batch already and it works great. Plenty of power and no smoke.
GrooveMerchant is offline   Reply With Quote
Old 10-17-2011, 07:22 AM   #20
DIY staff
Originally Posted by GrooveMerchant View Post
Ipeed, I mixed up one batch already and it works great. Plenty of power and no smoke.
No smoke is a good start.
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
