Drill Attachment For Screws? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 07:23 AM   #1
MarginallyQualified
Rewards Points: 2,464
drill attachment for screws?
Is there a good one?
Is there an adequate one for the occasional rocker?
Thanks.
eta: It appears that "The Dimpler" is it.
Old 02-17-2012, 12:09 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
most any of them are okay for the occasional rocker. I like only the magnetic shafts if you don't use them often? the hard part is remembering where they are.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-17-2012, 12:13 PM   #3
Rewards Points: 12,868
I just use a reguler phillips bit and an impact driver. Far more control then a cordless drill.
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
Looking for right angle drill attachment w/RPM doubler 6x6guy Building & Construction 0 10-21-2010 01:44 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
