Doubling Up Backerboard For An Exterior Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 08:29 AM   #1
Doubling up backerboard for an exterior wall?
Hi, I have decided to use Hardibacker 1/2" for my bathroom. I would like to use it on all the walls including a wall that starts in the shower and travels to the outside of the shower. Behind this wall is the exterior. By code in my area I can not use less than 5/8" wall for walls facing the exterior. Should I double up the length of the wall with 1/2"? If so, should I sandwich adhesive between the 2 boards?
joe bag is offline   Reply With Quote
Old 06-04-2011, 09:27 AM   #2
the Musigician
DangerMouse's Avatar
Welcome to the forum.
Where are you located? I've not heard of code requiring 5/8" drywall for exterior facing walls before.
Backerboard, tile, tub installl kathyll Building & Construction 26 02-15-2011 08:35 PM
Is it proper to tile over chipboard if backerboard is first laid? wvueers2004 Flooring 7 10-13-2010 05:22 PM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 05:11 AM
Install self leveling concrete ontop of backerboard then install tile? benshouse Flooring 7 01-04-2010 12:24 AM
Backerboard and Tile Project Question Livestrg05 Flooring 6 04-25-2009 07:35 AM
