Doorframes Flush With Framing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 01:28 PM   #1
Doorframes flush with framing
I am working on a bathroom renovation project in a '70s house.
All the doorframes in my house are flush with the frames. This is not something I did - the house simply came that way.
So, when I hang my drywall, it will essentially extend past the door frame by 1/2".
Do you have any suggestions on how to finish the edges of the drywall in this particular application?
will83 is offline   Reply With Quote
Old 08-08-2013, 02:50 PM   #2
Rewards Points: 13,270
Need to add what's called jamb extensions so the sheet rock comes close to the side of the jambs not over the ends of then,
http://www.bing.com/images/search?q=...electedIndex=3
That way the casing will cover the gap between the extension and the rough framing.
Do not try and make the extension flush with the old jambs. leave about 3/16" exposure. That way there's no misaligned trim that would need sanding or filler.
will83 (08-12-2013)
Basement Framing ddave23 Building & Construction 4 10-30-2011 11:38 AM
Framing Nailer of Death! Oh-Fudge Tools 6 09-15-2011 10:11 PM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 10:12 AM
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 08:17 PM
