Door Frame Not Even With Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 11:29 AM   #1
Rewards Points: 26
door frame not even with drywall
I installed a new entry door in my house and i made sure it was level and plumb. In order for the door to be plumb and seal right the frame of the door now sticks out(into the living room) about a 1/4" farther than the drywall at the top corner. Guess my wall is out of plumb a little, older house. What is the best way to trim this out to make it look nice? Thanks for your advice
ponch37300 is offline   Reply With Quote
Old 12-18-2008, 02:09 PM   #2
Trim.
Just sheet rock to the door frame and when you put the trim on it will more than likely cover it up fairly well.
I have to deal with this all the time. Some are worse than others and I have had to mud back 12 inches or so to get a nice transition when molding won't cover it good enough.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-18-2008, 02:17 PM   #3
RippySkippy's Avatar
When you get ready to put the trim on...you can always shave the drywall back a bit with a rasp so the shaved area will be hidden under the trim. 1/4" isn't anything...my last house was out 3/4" from top to bottom in a std 6-8 door....that was UGLY.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 12-18-2008, 03:28 PM   #4
Rewards Points: 26
Thanks for the advice, the door and frame actually are sticking into the living room by a 1/4", past the drywall so i am afraid that when i put the trim on there will be a gap between the trim and drywall?
Old 12-18-2008, 03:43 PM   #5
Oldguy
Rehabber's Avatar
Cut a furring strip to fill the gap, and then just caulk it in as usual
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-18-2008, 03:46 PM   #6
When you put the trim on you will have to put it at a slight angle so that it touches both the wall and the door frame. It will bridge the differences between the two.
Old 12-18-2008, 03:46 PM   #7
Custom Cabinet Maker
Ponch: Just pad the back of the trim with 1/4" lattice. Flush it to the back edge and trim as normal.
Jack
skymaster is offline   Reply With Quote
Old 12-18-2008, 08:28 PM   #8
Rewards Points: 85
Ponch,
If it's your house and want to make is look like a perfect fit go with what Marvin Gardens says to do. This will mean plastering and painting of course. Start with feathering out joint compound around the jamb where needed. This will probably take more then one application. After the plastering is finished check to see your trim sits nice and flush. Finish off the plastering to smooth it out and then apply your trim. As an extra bonus you'll now have to paint the wall that you just plastered.
Best of luck with the project, rredogg
rredogg is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Removing Old Drywall Fearless Freep Drywall & Plaster 5 10-03-2008 07:48 AM
drywall question billyg Drywall & Plaster 3 08-01-2008 09:49 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
