Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-27-2011, 03:49 PM   #1
Door case too small after sheetrocking
Looking for advice on what to do with windows and doors cases after sheetrocking. The issue is before I had paneling, and when I put the sheetrock up the door frames and windows will have a gap, since the sheetrock is thicker than the paneling.
Do I need to redo the door frames and windows completely? Or is there another option? Just wondering if anyone else had this issue.
Thank you in advance.
jburchill is offline   Reply With Quote
Old 05-27-2011, 05:34 PM   #2
firehawkmph's Avatar
Jb,
You need to add a jamb extension to your jambs. It should be the difference in thickness between your old paneling and the drywall, probably somewhere around 1/4" (which would be your gap showing now). You can either rip it on a table saw, or you may be able to find something the right thickness at a lumber yard or home center. The other dimension for your piece should be aprox. 3/4" to sit on your jambs. A brad tacker will fasten them up quickly.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Willie T (05-27-2011)
Small dip in concrete floor. kath81 Flooring 3 11-12-2010 05:32 PM
heating small bathroom floor - maybe rtoni Flooring 0 09-22-2010 04:11 PM
Small holes forming in newly poured concrete chitownIrish Building & Construction 4 07-10-2010 03:24 PM
Small room hardwwod refinish deejclow Flooring 1 04-29-2010 07:16 AM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
