-   -   Door case too small after sheetrocking (http://www.diychatroom.com/f101/door-case-too-small-after-sheetrocking-105776/)
jburchill 05-27-2011 02:49 PM
11 Attachment(s)
Looking for advice on what to do with windows and doors cases after sheetrocking. The issue is before I had paneling, and when I put the sheetrock up the door frames and windows will have a gap, since the sheetrock is thicker than the paneling.
Do I need to redo the door frames and windows completely? Or is there another option? Just wondering if anyone else had this issue.
Thank you in advance.
firehawkmph 05-27-2011 04:34 PM
Jb,
You need to add a jamb extension to your jambs. It should be the difference in thickness between your old paneling and the drywall, probably somewhere around 1/4" (which would be your gap showing now). You can either rip it on a table saw, or you may be able to find something the right thickness at a lumber yard or home center. The other dimension for your piece should be aprox. 3/4" to sit on your jambs. A brad tacker will fasten them up quickly.
Mike Hawkins:)
