Does This Corner Require A J-bead? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 02:58 PM   #1
Rewards Points: 1,062
does this corner require a J-bead?
Inside corner. Left drywall, right cement board (future tile)
Old 05-10-2012, 04:03 PM   #2
DIY staff
Rewards Points: 7,174
Just tape that like any other corner. Only add the top coats to the drywall side--No need to build up the corner where you will be applying the tile.
Old 05-10-2012, 04:30 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
^^ What Mike Said.....
- Build Well -
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 09:53 PM
Wrapping a 3/4 Ledger - Paper Faced Metal Corner, No Coat 450 or L Bead mobiledynamics Drywall & Plaster 1 03-29-2012 10:17 AM
Corner Bead Repair? How? kennykenny Painting 5 01-25-2012 06:55 PM
Metal corner bead on 20' soffitt MikeKy55 Drywall & Plaster 4 04-12-2011 06:18 PM
Taping corner bead? kupalino Drywall & Plaster 3 05-07-2010 08:58 AM
