Do You Always Muds With Lights... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 09:20 AM   #1
Rewards Points: 290
Do you always muds with lights...
Remodel - some it's not dealing with all new corners and edges....
In some area's, on on my 4th or 5th coat of mud...trying to do thin coats vs. overmudding/oversanding. And as always, when I turn on the lights (halogens) for final inspection, sanding.......the nit picker in me puts another thin coat on.
When is good - great enough....
Grrr...
I should stop inspecting it with the halogens ;-)
mobiledynamics is offline   Reply With Quote
Old 05-12-2012, 09:40 AM   #2
Rewards Points: 528
At some point, you will say enough is enough.
framer52 is offline   Reply With Quote
Old 05-12-2012, 09:56 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 582
If you really want to pull your hair out just take a regular light and lay it flat against the wall and let it shine across the wall or up the wall, you will see every imperfection there is. You will never get it perfect.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
chrisBC (05-15-2012)
Old 05-12-2012, 10:11 AM   #4
Rewards Points: 528
He could sell us tickets so we could watch him struggle to make it perfect!
Old 05-12-2012, 06:11 PM   #5
Learning Things Every Day
Jay 78's Avatar
I always keep a little LED flashlight with me when I do wall work. It's better to scrutinize your work while you're still in the prep stage - and can make corrections - than it is to discover flaws after applying your $60/gal paint.
Under Construction
Jay 78 is offline   Reply With Quote
Old 05-12-2012, 06:14 PM   #6
Rewards Points: 290
The 5th mud must be the charm as there were only a couple spots I needed to perfect ;-)
Yeah, I'm a stickler for flat walls and flat corners..
If you know how a corner looks with No-Coat vs. Metal Bead...and how tight a corner can be.
Leds are nice lighting and cool.
Halogens or a bright 75-100W handheld bulb is where it's at if you want the *light of truth*.
Old 05-13-2012, 08:52 PM   #7
Rewards Points: 512
i always use a halogen light and shine it towards the floor when sanding and from all different angles on the ceiling. you never know where the customer is going to put a light or they'll put in pot lights. also in the evening the sun may shine on the wall at a different angle so i better get it perfect. no call backs for this guy!
princelake is offline   Reply With Quote
Old 05-14-2012, 07:09 AM   #8
Stay-at-home GC
I'm a nit-picker. My first drywall finishing job was an 8x10 bathroom and I must have used a 5 gallon bucket of mud.
My advice, don't use an oblique light until your last sand.
Pay extra attention to high spots as you cannot sand them down once the primer goes on. DO NOT try and sand out low spots, circle them with a pencil and fill them.
Prime the wall. Now flashlight it once more. Any low spots you see now can be filled easily since you cannot scratch the underlying coats.
Any high spots will have to be floated out which is why you want to be religious about getting them before you Primer.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
