Do I Need Fire Resistant Drywall For This New Room? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 01:13 PM   #1
Do I need Fire Resistant Drywall for this new room?
Finishing out my basement this winter and had a question about fire resistant drywall. I was NOT going to finish inside my utility room and just leave the walls with studs on the inside. In the attached picture the grey top wall is existing concrete foundation, the grey wall on the left is existing against the stairs. The yellow on the bottom will be a hall and the yellow to the right will be a bathroom.
Do I need to finish the interior walls of this utility room with fire resistant drywall or can I leave them open. If I leave them open do the exterior of the walls (The interior to the hall and bathroom) need to then be fire resistant?
vseven is offline   Reply With Quote
Old 12-18-2009, 02:01 PM   #2
Registered User
Rewards Points: 4,936
Check Your City or County's web site or call your local Building Department for the only correct answer. This varies by locale. A few examples: http://www.aacounty.org/IP/Resources...ementGuide.pdf
Page 2 is interesting: http://www.pwcgov.org/docLibrary/PDF/005575.pdf
It may be regular drywall.... or not. You may need a weather-stripped door and outside air supply to any gas appliances. For sure you will be covering the walls with drywall for fire safety to protect your family.
Be safe, Gary
Old 12-18-2009, 02:09 PM   #3
the utility rooms like that i've seen usually have a vented door and are usually a 1-hour rating. however that is for commercial and institutional uses. residential code is a whole other animal and like GBR said you will have to check your local codes.
cellophane is offline   Reply With Quote
Old 12-18-2009, 02:18 PM   #4
The furnace has a outside air intake, the water heater does not so I probably either need to make sure there is a 1 - 2" gap at the bottom of the door or more likely have a door with a vent. I was thinking of also insulating the walls for noise control so maybe it would be best to just throw up some 5/8" fire resistant drywall inside the room.
Old 12-18-2009, 03:26 PM   #5
not a bad idea. just keep in mind that unless you follow a UL design for your wall and tape & fire caulk as required it is not a rated wall, instead just a wall with Type X GWB.
http://database.ul.com/cgi-bin/XYV/t...uv_search.html
i would still check with your local codes on what is required for that room.
Old 12-18-2009, 03:37 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Not much point in using 5/8" fire rated drywall with a vent in the door. Check your local building codes.
Old 12-19-2009, 04:00 PM   #7
Drywall contractor
Rewards Points: 1,070
As stated above, local codes will dictate, but as a rule utility rooms are not sheetrocked inside in a residential application. (And I'm speaking for this area.) Commercial jobs are another story. Again, as stated above, proper ventilation for the HVAC system is a must whether it is louvered doors, outside air intake, etc. Check the codes......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 05:17 AM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
