Do I Need Corner Bead - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 03:23 PM   #16
Rewards Points: 874
Originally Posted by djlandkpl View Post
Have you talked to a stone fabricator to see if what you want to do is reasonable? 1 1/4 (3cm) thick granite is probably close to 20 pounds per square foot. Serious injury will happen if the slab falls off that wall. If you want to hid the plywood substrate and you are doing a slab, your best bet is to use a thinner slab and have the edges doubled up. This will give the illusion of a thick slab while hiding the substrate.
I still think you should talk to a fabricator before going further.
I'm going to, thanks. We are also considering a tile countertop...heard that looks nice.
Mstrlucky74 is offline   Reply With Quote
Old 04-04-2013, 03:24 PM   #17
"You can do anything"-Mom
brockmiera's Avatar
I did a butt joint on 12"x12" granite tiles on the counter top in my rental. It looks really sharp and minimized the grout lines. The store I got them from had a prefabbed edge moulding, made of the same granite, that covered up my plywood base.
brockmiera is offline   Reply With Quote
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 10:53 PM
Metal corner bead question Firehawk734 Drywall & Plaster 15 06-12-2011 03:49 PM
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 4 04-24-2011 05:36 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
