Do I Need Corner Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 05:02 PM   #1
Rewards Points: 874
Do I need corner bead
We are just finishing up the wall that our counter top is gonna rest on. It will will overhung about 16" on one side and about 8" on the other. Do we need to corner bead at the top where the plywood and 2x6 meet? The counter is going to lay right on it and hide it. Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 04-03-2013, 05:29 PM   #2
Rewards Points: 13,712
Guess I'm confused why would you use plywood for this? And there's no way I can think of that a 2 X 6 is going to fully support a countertop that width.
It's been mentioned more then once that your going to need something wider.
Old 04-03-2013, 05:33 PM   #3
Bill Kearney
Rewards Points: 1,174
I wouldn't think so, but you might want to use a molding to cover the edge between them. It's tough to finish a drywall edge so even as to be perfect. Molding/trim helps hide this.
wkearney99 is offline   Reply With Quote
The Following 3 Users Say Thank You to wkearney99 For This Useful Post:
Mstrlucky74 (04-03-2013), oh'mike (04-03-2013), princelake (04-03-2013)
Old 04-03-2013, 05:39 PM   #4
ocd carpenter's Avatar
Either a wood or mdf moulding, or a drywall 'L' mould
ocd carpenter is offline   Reply With Quote
The Following User Says Thank You to ocd carpenter For This Useful Post:
Old 04-03-2013, 05:56 PM   #5
Rewards Points: 874
The sketch in this thread is no good???
Support for countertop
Old 04-04-2013, 08:06 AM   #6
Rewards Points: 5,974
I would just use a piece of J bead on the top of the drywall. And as far as the support issue goes are using corbels part of your design?
Old 04-04-2013, 08:29 AM   #7
Rewards Points: 874
Yes, or L brackets. I think also some sort of substrate as shown in the sketch in the above thread link. Not sure about the substrate though
Old 04-04-2013, 09:38 AM   #8
"You can do anything"-Mom
brockmiera's Avatar
I may be biased but I think that sketch is a work of art!
brockmiera is offline   Reply With Quote
Old 04-04-2013, 10:40 AM   #9
Rewards Points: 874
Lmao...it is and again thank you very much. Quick question .... The plywood substrate just gets attached to the top frame of the 2x6 wall and the the granite lays on top?? Of course either L brackets or corbels too.
Old 04-04-2013, 10:50 AM   #10
brockmiera's Avatar
Again, I've never worked with slab granite, only tile for countertops but that is the way I understand it. Use construction adhesive on top of your half walls then stagger your screws along the length of the wall.
Make sure if you sure metal L brackets instead of diagonal support like corbels you get a heavy gauge I'd say 16ga would be the lightest Id think about going.
Old 04-04-2013, 10:51 AM   #11
brockmiera's Avatar
How sturdy is that wall? Did you check it in all directions?
Old 04-04-2013, 10:59 AM   #12
brockmiera's Avatar
This is also assuming that you have some sort of bullnose finish that will hide the plywood substrate. What is the thickness of your granite top?
Old 04-04-2013, 11:56 AM   #13
Rewards Points: 32
Have you talked to a stone fabricator to see if what you want to do is reasonable? 1 1/4 (3cm) thick granite is probably close to 20 pounds per square foot. Serious injury will happen if the slab falls off that wall. If you want to hid the plywood substrate and you are doing a slab, your best bet is to use a thinner slab and have the edges doubled up. This will give the illusion of a thick slab while hiding the substrate.
I still think you should talk to a fabricator before going further.
Dan
djlandkpl is online now   Reply With Quote
Old 04-04-2013, 02:20 PM   #14
Rewards Points: 874
Unbelievably sturdy
Old 04-04-2013, 02:22 PM   #15
Rewards Points: 874
Probably going to be about 1 1/4 or 1 1/2". That's the other think....we are going to have to hide the plywood edges somehow
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 6 04-09-2017 07:39 PM
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 09:53 PM
Metal corner bead question Firehawk734 Drywall & Plaster 15 06-12-2011 02:49 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
