-   -   Do I need corner bead (http://www.diychatroom.com/f101/do-i-need-corner-bead-176213/)
Mstrlucky74 04-03-2013 06:02 PM
265 Attachment(s)
We are just finishing up the wall that our counter top is gonna rest on. It will will overhung about 16" on one side and about 8" on the other. Do we need to corner bead at the top where the plywood and 2x6 meet? The counter is going to lay right on it and hide it. Thanks.
joecaption 04-03-2013 06:29 PM
Guess I'm confused why would you use plywood for this? And there's no way I can think of that a 2 X 6 is going to fully support a countertop that width.
It's been mentioned more then once that your going to need something wider.
wkearney99 04-03-2013 06:33 PM
I wouldn't think so, but you might want to use a molding to cover the edge between them. It's tough to finish a drywall edge so even as to be perfect. Molding/trim helps hide this.
ocd carpenter 04-03-2013 06:39 PM
Either a wood or mdf moulding, or a drywall 'L' mould
Mstrlucky74 04-03-2013 06:56 PM
265 Attachment(s)
The sketch in this thread is no good???
http://www.diychatroom.com/f14/suppo...175388/index3/
ToolSeeker 04-04-2013 09:06 AM
I would just use a piece of J bead on the top of the drywall. And as far as the support issue goes are using corbels part of your design?
Mstrlucky74 04-04-2013 09:29 AM
265 Attachment(s)
Yes, or L brackets. I think also some sort of substrate as shown in the sketch in the above thread link. Not sure about the substrate though
brockmiera 04-04-2013 10:38 AM
I may be biased but I think that sketch is a work of art!
Mstrlucky74 04-04-2013 11:40 AM
265 Attachment(s)
Lmao...it is and again thank you very much. Quick question .... The plywood substrate just gets attached to the top frame of the 2x6 wall and the the granite lays on top?? Of course either L brackets or corbels too.
brockmiera 04-04-2013 11:50 AM
Again, I've never worked with slab granite, only tile for countertops but that is the way I understand it. Use construction adhesive on top of your half walls then stagger your screws along the length of the wall.
Make sure if you sure metal L brackets instead of diagonal support like corbels you get a heavy gauge I'd say 16ga would be the lightest Id think about going.
brockmiera 04-04-2013 11:51 AM
How sturdy is that wall? Did you check it in all directions?
brockmiera 04-04-2013 11:59 AM
This is also assuming that you have some sort of bullnose finish that will hide the plywood substrate. What is the thickness of your granite top?
djlandkpl 04-04-2013 12:56 PM
Have you talked to a stone fabricator to see if what you want to do is reasonable? 1 1/4 (3cm) thick granite is probably close to 20 pounds per square foot. Serious injury will happen if the slab falls off that wall. If you want to hid the plywood substrate and you are doing a slab, your best bet is to use a thinner slab and have the edges doubled up. This will give the illusion of a thick slab while hiding the substrate.
I still think you should talk to a fabricator before going further.
Mstrlucky74 04-04-2013 03:20 PM
265 Attachment(s)
Unbelievably sturdy
Mstrlucky74 04-04-2013 03:22 PM
265 Attachment(s)
Probably going to be about 1 1/4 or 1 1/2". That's the other think....we are going to have to hide the plywood edges somehow
