Do I Have To Paint Joint Compound? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 05:19 PM   #1
Do I have to paint joint compound?
I primed the ceiling then textured it using joint compound and a trowel. It is completely covered with joint compound. So my question is if I have the desired color and sheen with bare joint compound is it really necessary to paint it?
TSGR is offline   Reply With Quote
Old 02-11-2013, 08:30 PM   #2
Rewards Points: 626
yes the paint is there to serve as a protectant for the work you did. other wise you will have that texture on your head in a while after it absorbs the moisture in your home and the color will not last. it will be subject to stains and imposible to clean
Nailbags is offline   Reply With Quote
Old 02-12-2013, 07:22 AM   #3
Rewards Points: 5,978
You don't have to paint it, but you will find it won't hold that color very long. It will start to turn yellow, and it will show stains just from stuff in the air. Also it will absorb odors like crazy. On second thought yea you have to paint it.
Old 02-12-2013, 07:49 AM   #4
Ok thanks
Old 02-12-2013, 02:56 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
whenever, I used compound for texture? I'd mix paint into compound to desired color/consistency to work with. paint helps to harden the compound and can be worked like concrete to get no trowel marks. no match plaster, I used semi-gloss paint keeping trowel wet avoids pulling compound as troweling. dries hard, is a pain to remove when dry.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
Primer and Joint Compound Issues RIVO Painting 15 07-19-2013 10:47 AM
Joint Compound shaggy0125 Painting 8 01-12-2010 02:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
