Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-26-2011, 08:37 PM   #1
Send a message via AIM to chsitko Send a message via Yahoo to chsitko
Do I have a mold problem?
Hi, and thanks in advance for any replies.
Our Basement has some wood pannel with drywall behind it. We dont like the paneling and i am in the process of taking it down. My plan was to just put new drywall up over the old drywall so i dont have to bother with the mess. Im noticing along the base of the wall there is what looks to be surface mold, where the paneling was attached. Will i be okay to just scrub it off and then hang the new drywall over the old drywall, or do i need to remove all the old drywall and start from scratch.
chsitko is offline   Reply With Quote
Old 03-26-2011, 08:43 PM   #2
Masters in Drywall
MnDrywallRanger's Avatar
You should cut out a couple of spots to look behind it and see if you have mold behind the drywall.
I personally would just remove the old sheetrock instead of rocking over it in that situation.
MnDrywallRanger is offline   Reply With Quote
Old 03-26-2011, 09:21 PM   #3
So i pulled one of the panels all the way down, and there is some mold on the other side of the drywall, about the same amout as the front. The foundation wall and the 2x4's have no mold on them at all, so i think i am safe. I will take down the remaining drywall and put new drywall straight to the 2x4's. I'm assuming it would be better for me to use green board or some paperless drywall. Do i need one over the other?
Old 03-27-2011, 08:49 AM   #4
you could also measure up 4 ft +1/2" up from the floor snap a line and cut out everything below that line.
Then, hang sheets horizontally around the room rather than relacing everything.
williamwiens is offline   Reply With Quote
Old 03-27-2011, 09:34 AM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Chsitko, If you do end up replacing the drywall, definitely keep it off of the floor by at least a 1/2".
-Paul
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 03-27-2011, 11:04 AM   #6
Sir Mixalot, i think that is probably the main reason there is a little mold, it looks like the drywall wicked water up from the bottom, probably because it was placed to close to the floor.
Is there any other tips that can help the drywall not absorb moisture at the floor? Maybe wrap the moisture barrier from behind the drywall up the front an inch or two?
Old 03-27-2011, 04:41 PM   #7
Chsitko,
Instead of regular drywall, look for greenboard drywall. It is more moisture resistant than the regular and is meant to be used in basements or where it is more humid.
Keep it off the floor a good 1/2".
When you finish the wall, use a mildewcide in the primer and paint.
AandPDan is offline   Reply With Quote
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
Mold on framing of bathroom wall CowboyAndy Remodeling 34 10-22-2010 07:53 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
