Do Drywall Panels Have To Meet On A Stud? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 10:05 AM   #1
Rewards Points: 107
do drywall panels have to meet on a stud?
The bathroom I am building has one wall inset 3" off the XPS for running the piping for a Saniplus. Due to that the 16" spacing will not be accurate on two of the walls. Do I need to nail in some additional studs to make the panel ends meet on a stud? That will really screw up my insulation then won't it?
dwcopple is offline   Reply With Quote
Old 04-07-2012, 10:15 AM   #2
Framing Contractor
Rewards Points: 120
Insulation is easily cut.
sixeightten is offline   Reply With Quote
Old 04-07-2012, 10:18 AM   #3
Rewards Points: 13,968
Not the perfect way but you can just add a 4 to 6" wide strip of wood behind the seam so there's a backing where it gets attached on both sides.
Anything will work, plywood, 1 X, 2 X 4 laying flat.
Old 04-07-2012, 10:32 AM   #4
Too Short? Cut it Again!
I can see toenailing 2x4 blocking flat I guess but nothing thinner and why not use the 2x4 blocking on edge?
Old 04-07-2012, 10:41 AM   #5
Framing Contractor
Facenail a 2x6 flat into the stud and toenail into the top plate and bottom shoe and your done.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (04-07-2012)
Old 04-07-2012, 11:10 AM   #6
Remodeling Contractor
use backer board.... it is a taperedd panel made for drywall seams. This allows the seams to be pulled in so no "bump" is visible after compounding. The best way is to never place butt seams over a stud anyway. And with this you have full bay spacing for easy insulation installation.
The Following User Says Thank You to Bob Mariani For This Useful Post:
Willie T (04-07-2012)
Old 04-07-2012, 01:09 PM   #7
Rewards Points: 107
got a link for that product?
Old 04-07-2012, 01:40 PM   #8
Go to any professional drywall supply house. Or make your own. Use a piece of scrap 1/2 plywood about 48" long and 6" wide. glue a 1/4" wide 1/2" plywood strip to the outer edges. This provides a taper which will pull in the edges of the drywall at the center. You could even run a bead of caulking along the outer edges and let it dry over night. To install just hold it against one sheet of drywall that was installed and screw it tight. Now install the other piece. You will notice a slight bulge inward at the seam. so when you tape and add compound the joint is flat and not bulging out like a not pro would do.
Old 04-07-2012, 03:29 PM   #9
Old School
Willie T's Avatar
Go HERE for instructions on making your own BUTT BOARDS.
Willie T
Old 04-08-2012, 08:03 AM   #10
Not sure if I am missing something but unless it is a huge bathroom why not just hang your sheets horizontally and go from corner to corner ? Thats what I would do.
kj6887 is offline   Reply With Quote
Old 04-08-2012, 08:07 AM   #11
Rewards Points: 107
I may do that, but one corner will be durock or dens shield for tile for the corner shower. I was just concerned that I needed seems to meet on a stud. Two walls have 32" entry doors and the other two are the ones that will have backerboard for hanging the tile. Bathroom is 7'2" x 9'3" inside dimensions.
Old 04-08-2012, 08:17 AM   #12
Then to answer your question... yes there needs to be something there one way or another.
Old 04-08-2012, 07:12 PM   #13
In a little over my head
Rewards Points: 706
Seems to me like an extra stud and a cut batt is the easiest solution.
ratherbefishing is offline   Reply With Quote
Old 04-08-2012, 10:26 PM   #14
Framing Contractor
Bob,
All that work when you can just nail a 2x6 and be done with it, why??
Joe Carola
Old 04-09-2012, 07:07 AM   #15
Rewards Points: 107
I've got a bunch of scrap 8' 1x4's. Can I just use a couple of those flat behind the seam?
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 10:11 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
removing drywall from stud gtw010 Drywall & Plaster 5 02-02-2011 04:03 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
