Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-20-2012, 06:38 PM   #1
DIY basement walls
What is the best wallboard for a damp basement. Making a bedroom for my 5 yr.old twins.
JJP12 is offline   Reply With Quote
Old 07-20-2012, 08:32 PM   #2
Super Moderator
DIY basement walls
There is a mold resistant drywall---purple I think---but mold will invade the insulation and grow on the studs----
Is there any way to condition the area?
Old 07-21-2012, 07:22 PM   #3
DIY basement walls
I would just use regular white board except for bathrooms and in direct water.
If you have that much mosture in a bedroom you will have worse problems than drywall.
Just hold the drywall off the floor when you hang it.
scottktmrider is offline   Reply With Quote
Old 07-22-2012, 01:12 AM   #4
DIY basement walls
My preferred basement drywall method is -
Keep the drywall 3" off the floor, put a strip of treated plywood in that is 2.5" keeping it 1/2" off floor.
Cover with 4" baseboard.
That way water does not get at the bottom of the drywall.
Also use 2" of Styrofoam in the bottom of the wall if it has fibreglass insulation. It won't wick up water.
mae-ling is offline   Reply With Quote
Old 07-23-2012, 02:49 PM   #5
DIY basement walls
You sure you want to put anyone, let alone 5 year olds in a damp basement? I developed a very bad cough that I'm pretty sure would have killed me eventually when I lived in a basement for a couple of years.
mikegp is offline   Reply With Quote
Old 07-23-2012, 03:11 PM   #6
Stuck in the 70's
Blondesense's Avatar
DIY basement walls
My parents "framed in" a bedroom in their unfinished basement. Two years ago, when DH and I stayed down there he ended up with significant breathing problems by the time we left. It cleared up once we got home.
The last time I was there (without DH) you could see mold spots on the door and walls. I slept upstairs in the den.
Get rid of any moisture problems/issues BEFORE you even consider letting anyone sleep down there permanently.
Old 07-23-2012, 03:27 PM   #7
DIY basement walls
Are you a member of the bump or other maternity forums? What is dh? Dear husband? I always wondered that.
Old 07-23-2012, 04:53 PM   #8
Stuck in the 70's
DIY basement walls
Answer is No to the other forums.
And yes, DH = Dear husband.
DW = Dear wife.
SO = Significant other, etc. etc.
Old 07-23-2012, 05:16 PM   #9
DIY basement walls
Just a guess;dehumidifier?
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 01:36 PM
What to do with basement walls. RR. Remodeling 3 02-20-2012 07:49 PM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 01:44 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
