Did Not Use Alkali Resistant Fiberglass Mesh - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-13-2014, 08:26 PM   #1
did not use alkali resistant fiberglass mesh
The shower pan in my master bath started leaking and I am replacing it with a new shower pan because fiberglass was weak and flexing. So I took out a row of 12" cultured marble tile and replaced the shower pan. The drywall at the bottom of was bad so I went up another row to get to sound backing and I put in about 18" DensShield I did not realize that I needed to use alkali resistant mesh when I taped it and used mold resistant mesh with the latex modified thinset. ... So how bad off am I? What do I do to correct it, or should I just press on.
sartras is offline   Reply With Quote
Old 04-13-2014, 08:52 PM   #2
DIY staff
Rewards Points: 7,174
Just press on---the mesh will have a shorter lift--but not necessary to redo it==
Did you add a waterproofing to the top of your repair?
That would be a good touch--Red Guard ?
As you have learned the hard way---drywall of any kind is a bad backer for tile in a wet area.
Old 04-13-2014, 11:49 PM   #3
Rewards Points: 626
two coats of either red guard or hydroban will do the trick and your ready to go
Nailbags is offline   Reply With Quote
Old 04-14-2014, 08:20 AM   #4
Rewards Points: 6,034
You should be fine with the tape. The seam is filled with thin set and the tile should not allow much flex.
Old 04-14-2014, 06:56 PM   #5
Thanks All
I was a bit down and wondering if I should just tear it all out and start from scratch. Red Guard at Home Depot only comes in a $50.00 container, I suspect Hydro Ban might be more expensive. I guess it is worth it to cough up the $50.00 even though I don't need much for the small area.
Old 04-16-2014, 10:21 AM   #6
Rewards Points: 626
Either one is good. two coats and it is water proof. I like hydroban better works better in preventing cracks in the tile work as well Hydro ban from lati-crete is around 75 dollars per gallon and well worth it. think of it as do I want mold and rot and redo this again?
Tags
alkali resistant mesh , densshield , thinset
Improving attic insulation: remove old fiberglass or just add cellulose/fiberglass? DrSteveBrule Insulation 12 10-21-2013 11:42 PM
how to make a cylindrical box out of mesh anorphirith Building & Construction 2 02-25-2013 12:20 AM
difference between fiberglass insulation for house and ovens Druidia Insulation 2 08-03-2012 08:44 AM
12"x12" mesh back mosiac tile above fiberglass shower SER56 Kitchen & Bath Remodeling 3 03-01-2012 07:32 AM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 10:16 PM
