-   -   DeWalt Drywall gun (http://www.diychatroom.com/f101/dewalt-drywall-gun-127232/)
TurboDIYer 12-20-2011 07:57 PM
DeWalt Drywall gun
Hey, I have been wondering if anyone has used the DeWalt drywall gun and do they adjust manually or automatically to really install drywall that fast.
coupe 12-20-2011 08:10 PM
all screwguns, are first set manualy for depth of screws. then stay at that setting.
at least all I've seen
as always, just my thoughts.
good luck
take what helps? ignore the rest!
coupe/Larry
woodworkbykirk 12-20-2011 08:55 PM
coupe is right. the odd time you will find a bad screwgun which the depth set shifts on its own
hilti and milwaukee are prob the best ones available. one i would definitely avoid is the ridgid.. two major issues with them which ive seen on 4 different units were that he tip wouldnt stay in the gun and the direction button is very sensitive... too many times ive seen ridgids thrown at the floor
the dewalts are fine, just the stock philips tip's dont last very long but thats a $0.75 fix. most dewalt driver tips are too soft and strip out really easy
joecaption 12-20-2011 09:03 PM
If you going to use this for just one job then there's better ways then a drywall gun.
They sell tips that can go in drills or impact screw drivers that do the same thing as a screw gun.
joecaption 12-20-2011 09:08 PM
http://www.amazon.com/Goldblatt-G158.../dp/B0001IW568
coupe 12-21-2011 01:27 PM
the question was on the Dewalt screw gun. I stand by my statement, you must first manually set for depth of screws! the adapter, is pre set. should work fine? keep in mind, all of them must be held in straight position to go in correctly and countersink. or will strip tips going in on angles!
good luck
coupe/Larry
ryan5068 12-23-2011 08:21 PM
Those tips are a far cry of a drywall screw gun. I've used my dewalt on thousands of screws. Go to ebay and pick one up. Not very expensive. Forget the tip
Missouri Bound 12-23-2011 08:42 PM
I totally agree. No reason for a home owner to buy a drywall gun for his own projects.:thumbsup:
jburchill 12-23-2011 09:28 PM
11 Attachment(s)
How big is the job? How much drywall you have to hang?
ryan5068 12-24-2011 09:56 PM
I've hung probably 200 sheets with my gun but you know what, I like to have some tools that friends can use too. My screw gun has helped out about 4 friends to do their basements. I have a jack too that I rarely use too but all my buddies know I have it. There is gratification knowing you are helping others too. Used guns are around 60.00 on ebay
BigGuy01 12-25-2011 12:16 AM
You mean a cordless drill, with drywall screws?
It's as difficult as having someone hold a drywall board in place, and then having someone put a drywall screw on the tip of a drill bit of a cordless drill, and then pulling the trigger and putting weight behind the drill, pushing the screw in just beneath the surface, stopping the drill, and repeating that every 8'' down on each stud.
I can tell you right now, you can put screws into drywall faster with a "speed reload" and a regular 18v screw gun. How? SImple. Take your left hand (if you're right handed) put 10-20 screws in it, all facing the same direction. cycle screws between your middle and index finger one at a time as you put them in. If you're talking about speed, and efficiency with accuracy, you can put in 30 screws a minute doing this method. Which there is no Drywall gun that could even compare to manually feeding screws to a regular screw gun.
EDIT
3 men can drywall an entire 1600sq ft house in a day (including the cieling) minus the joint compound and taping doing this method.
jproffer 12-25-2011 02:22 AM
:no::huh::no::huh:
They may have some that adjust automatically, but most adjust manually one time....then it's "set" and you can "get with it" :thumbsup:
TurboDIYer 12-28-2011 01:07 PM
I'm a General Contractor so I'm using it for my team/crew.
TurboDIYer 12-28-2011 01:09 PM
EDIT
As a General Contractor, I have used that method on my jobs but after watching an episode of Holmes Inspection, I see these guys using a DeWalt screw gun screwing on the drywall at like literally 2 screws a second.
jburchill 12-28-2011 01:17 PM
11 Attachment(s)
I bought a dewalt drywall gun for the remodel of my basement. And I am a DIY home owner. Not a general contractor or professional drywall installer.
Reason I bought mine was it is faster to hang drywall and was easier to hang drywall when working alone. Also, I wanted to buy it.
I have the dewalt 272 model and it is a manual for setting the depth. I did notice that you will have to adjust the settings occasionally. I noticed it when drilling into old studs compared to new studs.
If you are buying for your crew I'm guessing you'd be hanging more drywall in the future and would recommend buying a drywall gun. I liked my dewalt, but other might be just as good.
