Darker Spots On Ceiling Drywall Any Issues With This? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 10:50 PM   #1
Rewards Points: 366
Darker spots on ceiling drywall any issues with this?
It's not too noticeable but under the right lighting conditions and viewing angle, you can see some subtle darker spots (or hue) on the white ceiling drywall.
the dark spots reveal lines like where the attic/ceiling framing wood (beams or joists?) would be, and around IC rated recessed lighting. The attic has fiberglass insulation sitting atop the ceiling alongside the framing, and has 2 vents on roof and one gable vent along the wall outside
Is that expected/normal or indicate not good installation of attic or the drywall ceiling? Moisture/condensation problem? Or darken from heat in the attic or recessed lighting?
I can post a photo later though can't tell yet whether photo can show the subtle dark spots.
daluu is offline   Reply With Quote
Old 09-27-2012, 12:46 AM   #2
DIY staff
Rewards Points: 7,174
Has the drywall been painted?
Some soot staining occurs along joists and fasteners---they are cold spots--condensation on the cold spots will pick up air born soot--and stick there---
Smokers---candle burners and wood stove users need to paint more frequently because of that.
Old 09-27-2012, 03:35 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
Mike is right
chrisn is online now   Reply With Quote
Old 09-27-2012, 08:22 AM   #4
Rewards Points: 13,458
It's called ghosting, Google it.
Old 09-27-2012, 11:15 PM   #5
Rewards Points: 366
Thanks for the info. That makes sense. When we toured the house one day for inspection (while previous owners were there) we saw condensation on some windows, and owners were cooking (w/o vent fan on) & drying clothes @ the time, so could be ghosting & soot.
If painting, just paint over or need cleaning w/ bleach, etc. Treating the soot/discoloration like mold/mildew?
Old 09-27-2012, 11:31 PM   #6
Registered User
Rewards Points: 5,498
No bleach, it's just dirt- as Mike said. Page 11: https://docs.google.com/viewer?a=v&q...BiEiG1lHFDd9yA
Gary
Water Damage: Repairing Ceiling Drywall Defects at Seams? Lovegasoline Drywall & Plaster 5 04-24-2012 06:57 AM
drywall on skylight shaft walls above ceiling amakarevic Drywall & Plaster 5 03-25-2012 10:53 AM
Ceiling Water?? Spots Linkin16 Building & Construction 2 01-22-2011 02:51 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
