Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-15-2011, 10:12 PM   #1
damaged sheetrock/compound joint/texturing
We applied joint compound to the bathroom sheetrock wall that was damaged down to the brown part in sections. It of course, bubbled. Now, my hubbie is sanding it. Is it ok to prime and paint afterwards?
Thank you,
Aunt Gigi
auntgigi1 is offline   Reply With Quote
Old 08-15-2011, 10:28 PM   #2
Tileguy
Bud Cline's Avatar
Not if it bubbled under the moisture of the joint compound. Peel the loose paper and patch it again and see if it takes this time.
How do I remove part of the damaged subfloor? ChEMom Flooring 17 07-15-2011 01:28 PM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-02-2010 12:21 AM
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 11:00 AM
Damaged brick work Redders Building & Construction 1 04-02-2009 11:59 AM
Termite Damaged Sill Plate cary00silve General Discussion 17 01-07-2009 02:52 PM
