Cutting Out Big Holes - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 11:45 PM   #16
Retired from the grind
Rewards Points: 6,652
Originally Posted by Mijotter View Post
For standard walls sure. But i'm building a theater room and sound proofing by double walling it(room within a room) Going to turn out great
Again over kill. You really need to decouple the Gypsum from the studs, but first off, the studs for the walls need to be properly built, since they will be the weakest link. As for sound through any duct work, there is no way to stop that, unless you use the proper materials, and they have to be fire rated, if you line the ducts.
Also no need to crank the volume up so high, that people think that you have Motorhead playing in your house. The loudest that we turn our system up to, is maybe -12db, which is enough for us. Most times, it is maybe at -18db for about everything, including movies.
See http://inspectapedia.com/BestPractic...nd_Control.htm
Tags
butt joints , drywall , fish tank , hole , seam
Need advice cutting 10" speaker holes Mr. spock Drywall & Plaster 18 01-08-2013 07:34 AM
Cutting holes for can lights in sheetrock j_sun Drywall & Plaster 6 09-23-2012 07:47 AM
your preferred method of cutting holes for boxes in plaster latt Hardway Electrical 5 03-06-2012 08:34 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 06:20 PM
Holes in flange dont match holes in toilet! ljenkins Plumbing 2 02-06-2010 07:17 AM
