Cutting Holes In Wonderboard - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 08:16 PM   #1
cutting holes in wonderboard
Hello,
What is the best method to cut holes for plumbing in wonderboard? I didn't know if regular hole saw will do it without wrecking the hole saw.
Thanks,
Mike
Mike L is offline   Reply With Quote
Old 08-31-2010, 09:26 PM   #2
Rewards Points: 6,652
Wonderboard is the worst stuff to use. Denshield is the best to use in wet locations, Durock everywhere. I opted for Denshield, since it cuts like Gypsum board, and you do not need special blades to cut.
Old 08-31-2010, 09:56 PM   #3
Civil Engineer
Rewards Points: 4,520
I cut wonderboard with carbide toothed holesaw, works fine.
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
cutting 4" holes in 10" floor joist red_cabby Building & Construction 19 06-22-2010 05:25 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
Interior: Preserving Installation Screw Holes During Skim coating? Lovegasoline Building & Construction 4 09-29-2009 04:03 PM
Cutting holes in plastic J-Box jamiedolan Electrical 15 02-25-2009 06:58 PM
