Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-10-2008, 10:54 PM   #16
cutting drywall
Plus it's no big deal to fix drywall.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-11-2008, 01:30 PM   #17
cutting drywall
A DIYer is better off marking the sheet and carefully cutting the boxes out manually, or prior to installing the sheet on the wall (on their smaller projects).
I'll have to disagree. If the hole is over 1/4" off at the top/bottom, the device tabs wont land on the drywall and you end up with problems. It's tough to transfer/transpose accurate box dimensions. That's why everyone uses rotozips nowdays.
Sometimes.
220/221 is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Cutting drywall to put in windows down a stairwell ragtopdave06 Remodeling 9 02-14-2007 08:32 PM
Cutting drywall hdayanan Remodeling 5 02-24-2006 10:19 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
