Cutting Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 10:18 AM   #1
Rewards Points: 150
cutting drywall
Has anyone used any of the electrical box marking systems for cutting out drywall? Seems like they could save an amature like me a lot of time and measuring. HD sells one called blind mark, any good? BTW, I have recently purchased a dremmel that I think can help with this task.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 12-08-2008, 10:48 AM   #2
I just get the retro box and cut the hole using that as a template.
Be careful using any kind of power tools when doing this. They can get away from you real fast and a simple install can lead to lots of sheetrock patching.
And oversized covers really look ugly to me.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-08-2008, 11:25 AM   #3
I use a dremel for the paint, don't want to chip that! Then I just use a hand drywall saw to cut. If you just use the drywall saw, you might pull paint off.
I use a laser leveling device to be sure its even.
rgsgww is offline   Reply With Quote
Old 12-08-2008, 01:06 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hang the drywall over the box then use a cutout tool like a rotozip. Simply pop it through the drywall close to the box move over till you hit the outside edge then move around the box in the direction that the torque pushes into the box. Make sure all your wiring is tucked inside the box of course. You then just patch the short cut in the drywall with mud when finishing.
Old 12-08-2008, 01:35 PM   #5
Or find the inside of the box first then pull the rotozip out and re enter exactly on the outside. No patch/fill this way, just an occaisional wire scuff.
220/221 is offline   Reply With Quote
Old 12-08-2008, 03:36 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Common, you guys should know enough about this. It's not that easy.
In fact, rookie drywallers take about 100 to 200 sheets of sheetrock before they even start to get the hang of it (using a router/rotozip without butchering the area), besides all the cut up wiring they do, before they learn how to do it right....
A DIYer is better off marking the sheet and carefully cutting the boxes out manually, or prior to installing the sheet on the wall (on their smaller projects).
- Build Well -
Old 12-08-2008, 04:18 PM   #7
Agreed. An amateur with a rotozip can do a lot of damage. Get a good keyhole saw and razor knife and learn how to cut boxes by hand.
jerryh3 is offline   Reply With Quote
Old 12-08-2008, 06:12 PM   #8
Rewards Points: 508
Send a message via AIM to theatretch85
I've never had paint chip with a drywall saw when cutting holes for boxes, and so long as your keeping the hole cut-out small any paint chipping would be covered by the wall plate.
I fully agree!
BTW to the OP, I have seen articles and reviews on the BlindMark, never actually used it myself but it looks like it has the potential to save you some time. Though I suspect it will take some getting used to just to get the holes right. The box protrudes from the stud face at least a 1/2" (should anyway) so the drywall won't be flush up against the studs until you cut the hole for the boxes; could be kinda tricky for a novice.
theatretch85 is offline   Reply With Quote
Old 12-09-2008, 11:21 AM   #9
UAW SKILLED TRADES
Stubbie's Avatar
I'm sorry for giving the guy some choices to try please excuse my ignorance. 100 to 200 sheets to get it right...maybe you should tell the apprentice to open his eyes....
Old 12-09-2008, 11:28 AM   #10
Did mean anything negative by it. A rotozip is a great tool. But there is a learning curve. If the OP is going to do a lot of new drywall, learning to use one might be beneficial. Start in bedrooms or closets where the cuts won't been seen.
Old 12-09-2008, 11:44 AM   #11
UAW SKILLED TRADES
Stubbie's Avatar
Assuming the guy uses a fairly new cutout tool it really isn't that hard if he uses his depth gauge. They are vastly improved over the older models. As you gain skill you remove it. Measuring and cutting holes is also a skill in itself to get the hole where it does not require patching and can result in many wasted sheets. I'd take my chances with a cut out tool any day novice or not. Patching....you guys sound like that is a cardinal sin...I guarantee a novice will need to patch just as much and patching will be more severe trying to measure out the box or ceiling location prior to hanging the sheet. Most drywallers use a combination of both depending on the situation. A cutout tool is simply a slit in the drywall if you error. A hole cut wrong or off by 1/4 inch or more requires a major repair to fill the gap or recutting a new sheet.
Old 12-09-2008, 11:51 AM   #12
Good points. As to the keyhole saw, I was referring to cutting the box after the sheet is tacked in place.
Old 12-09-2008, 12:29 PM   #13
UAW SKILLED TRADES
Stubbie's Avatar
That's a good way to do it...we are simply giving the guy some options.
Old 12-10-2008, 06:44 PM   #14
Rewards Points: 150
Jeepers guys, I didn't think I'd stir up such a controversy here. I appreciate all of the advice given. Tell you what I'm gonna do, I have a lot of drywall scraps and I'm going to do a few mock ups with 2x4's and boxes to try to get "the feel ". Wish me luck
Warren Zevon
Old 12-10-2008, 09:50 PM   #15
Rewards Points: 150
i am a diyer. idid this the rotozip way. i messed up two holes before i got the hang of it. then i did about twenty good after. i sugest you get the rotozip.
drewhart is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Cutting drywall to put in windows down a stairwell ragtopdave06 Remodeling 9 02-14-2007 07:32 PM
Cutting drywall hdayanan Remodeling 5 02-24-2006 09:19 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
