Custom Tile Shower Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 10:32 AM   #1
Rewards Points: 16
greenboard vs cement board for tile shower ceiling
I recently had my basement drywalled. The drywaller used cement board for the all the walls in the shower area and greenboard for the ceiling. The walls and the ceiling will both be tile.
I am having a separate contractor tile and finish the entire bathroom and shower. Should I have the new contractor replace the green board in the shower ceiling with cement board? I have read conflicting opinions on this matter
I'm not sure if this impacts the answer but I strapped the ceiling so that my floor joist span is only 10" so the greenboard is ok from that point of view. And I plan on using a kerdi membrane system for the walls and ceiling.
thanks
mj
maljeff is offline   Reply With Quote
Old 08-21-2012, 11:07 AM   #2
Rewards Points: 4,792
Well if you're using Kerdi on the ceiling, then of course you don't have to replace drywall with cement board.
jeffnc is offline   Reply With Quote
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Tile shower surround meeting sheetrock on wall? forkandwait Kitchen & Bath Remodeling 3 03-01-2012 11:57 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Tile shower surround above fiberglass shower Gregghea Tiling, ceramics, marble 3 01-28-2011 08:39 AM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
