Curved Corners - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 09:38 PM   #1
curved corners
Hello all, I have a new home, just moved in, noticed when I walked in what appeared to be a curve in my pantry wall, or instead of being straight is was bowed inward a very noticeable amount. Since this discovery I looked at other walls and am seeing the same thing. Builder says this is due to corner bead mud. I completely understand no stick built wall will be perfectly straight, but should the curvature out near the end of the walls be noticeable with the naked eye...Im talking quarter to one half inch. Any info greatly appreciated
wally572 is offline   Reply With Quote
Old 08-29-2013, 07:03 AM   #2
Rewards Points: 6,034
Really hard to say without a pic but VERY doubtful if corner bead mud unless he had an incompetent drywall finisher. But it really doesn't matter if this is a new home he should fix it.
Old 08-29-2013, 07:10 AM   #3
Rewards Points: 14,306
Just a guess, sounds like they did not do one of to things. Leave the outside corners of the sheetrock cut back enough so as the corner bead was installed it make it stick out.
Or they did not use a wide enough drywall knife to even it out away from the outside edge.
Old 08-29-2013, 07:16 AM   #4
Tiling steps with curved corners sgjordan Flooring 3 05-12-2013 07:32 PM
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Need advice on molding and curved corners g9_diy Carpentry 4 06-10-2012 11:51 AM
curved wall and curved floor joins pstur1 Building & Construction 2 12-05-2010 12:01 PM
