-   -   curved corners (http://www.diychatroom.com/f101/curved-corners-186135/)
wally572 08-28-2013 09:38 PM
curved corners
Hello all, I have a new home, just moved in, noticed when I walked in what appeared to be a curve in my pantry wall, or instead of being straight is was bowed inward a very noticeable amount. Since this discovery I looked at other walls and am seeing the same thing. Builder says this is due to corner bead mud. I completely understand no stick built wall will be perfectly straight, but should the curvature out near the end of the walls be noticeable with the naked eye...Im talking quarter to one half inch. Any info greatly appreciated
ToolSeeker 08-29-2013 07:03 AM
Really hard to say without a pic but VERY doubtful if corner bead mud unless he had an incompetent drywall finisher. But it really doesn't matter if this is a new home he should fix it.
joecaption 08-29-2013 07:10 AM
Just a guess, sounds like they did not do one of to things. Leave the outside corners of the sheetrock cut back enough so as the corner bead was installed it make it stick out.
Or they did not use a wide enough drywall knife to even it out away from the outside edge.
joecaption 08-29-2013 07:16 AM
