Crumbling Plaster: Water Damage? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 02:55 PM   #1
Crumbling plaster: water damage?
Hey y'all, I got a church building here that's about 80 years old. Exterior's brick; the paint and plaster have been peeling and crumbling away on the inside. It's gotten pretty bad, and we need to know how to deal with it at this point.
I don't know hardly anything about brick buildings; I have been told we need to re-seal the exterior brick before dealing with the plaster problem. I attached a few pictures - does this look like it's primarily a moisture issue? I'm afraid if we just patch things up inside, that moisture would lead to the same problem in a short time.
Thanks in advance!
Crumbling plaster: water damage?-building2.jpg   Crumbling plaster: water damage?-building3.jpg   Crumbling plaster: water damage?-building4.jpg
guruofgentoo is offline   Reply With Quote
Old 11-05-2013, 03:11 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
why yes it sure looks like moisture damage to me
Old 11-05-2013, 03:13 PM   #3
OK, very good then, thanks. Is re-sealing the exterior the way to go, or is there another step? Do we need to treat the existing plaster somehow before patching it?
Old 11-05-2013, 03:15 PM   #4
Rewards Points: 5,974
Yes it's moisture and should be addressed ASAP. Until then it will only get worse.
Old 11-06-2013, 12:53 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Afraid it's a little late to treat the existing plaster. Fix the moisture intrusion problem. Then scrape out what's already compromised and redo it. If it's soft, it has to go.
Tags
masonry , plaster , water damage
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 09:57 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
garden hose water spillage: damage to pipes, huge water bill? cluelessDIYer Plumbing 5 06-26-2010 12:42 PM
Water damage on plaster controlnovice Building & Construction 2 05-21-2008 12:34 PM
