Crumbling At Bottom Edge Of Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 03:18 PM   #1
Rewards Points: 248
Crumbling at bottom edge of drywall
The drywall was installed incorrectly and as a result the bottom edge next to the floor crumbled in several places. When/if that happens is it better to remove the panel and lift and start over or just cut the crumbling pieces and fix it with putty?
jackwashere is offline   Reply With Quote
Old 08-13-2012, 03:28 PM   #2
Rewards Points: 212
Did you see this post further down the list
crumbling drywall
orange is offline   Reply With Quote
Old 08-13-2012, 03:47 PM   #3
Rewards Points: 248
crumbling drywall
Yes I have and it's about damp and wet drywall. I botched my installation. I thought the guy I hired to help me was an expert. He would start to screw the drywall in about the middle. By the time the bottom was ready to screw there wasn't enough room. So the bottom edge of the drywall crumbled and cracked as it was pushed in to fit. It seems like a completely different type of crumbling and fix.
Old 08-13-2012, 05:54 PM   #4
Rewards Points: 13,732
To late now but the rock was suppost to be 1/2 up off the floor.
Can you post a picture?
May be able to just cut it off, (an ossilating saw works best).
The baseboards going to be covering up the flaws.
Old 08-13-2012, 06:08 PM   #5
Rewards Points: 248
So you suggest I cut and fix when possible, not remove and reinstall? Removing drywall once installed is pretty dirty and may create new problems.
Old 08-13-2012, 06:17 PM   #6
Without that picture everyones going to guess how bad it is.
Old 08-13-2012, 07:18 PM   #7
Rewards Points: 454
How far up does the rot go?
scottktmrider is offline   Reply With Quote
Attach drywall at the wall bottom Restyle Drywall & Plaster 8 12-15-2011 10:25 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
