-   -   Crumbling at bottom edge of drywall (http://www.diychatroom.com/f101/crumbling-bottom-edge-drywall-153576/)
jackwashere 08-13-2012 03:18 PM
The drywall was installed incorrectly and as a result the bottom edge next to the floor crumbled in several places. When/if that happens is it better to remove the panel and lift and start over or just cut the crumbling pieces and fix it with putty?
orange 08-13-2012 03:28 PM
Did you see this post further down the list
http://www.diychatroom.com/f101/crum...rywall-153299/
jackwashere 08-13-2012 03:47 PM
Yes I have and it's about damp and wet drywall. I botched my installation. I thought the guy I hired to help me was an expert. He would start to screw the drywall in about the middle. By the time the bottom was ready to screw there wasn't enough room. So the bottom edge of the drywall crumbled and cracked as it was pushed in to fit. It seems like a completely different type of crumbling and fix.
joecaption 08-13-2012 05:54 PM
To late now but the rock was suppost to be 1/2 up off the floor.
Can you post a picture?
May be able to just cut it off, (an ossilating saw works best).
The baseboards going to be covering up the flaws.
jackwashere 08-13-2012 06:08 PM
So you suggest I cut and fix when possible, not remove and reinstall? Removing drywall once installed is pretty dirty and may create new problems.
joecaption 08-13-2012 06:17 PM
Without that picture everyones going to guess how bad it is.
scottktmrider 08-13-2012 07:18 PM
How far up does the rot go?
