Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-05-2011, 07:40 PM   #1
Creating Corners in my Baesment Drywall
How do I get sharp nice corners in my basement corners?
MuzSop828 is offline   Reply With Quote
Old 07-05-2011, 08:13 PM   #2
Too Old
Corner bead for outside corners, and use an inside corner trowel for the inside corners.
havalife is offline   Reply With Quote
Old 07-05-2011, 10:27 PM   #3
MikeKy55's Avatar
I did mine by 1.) taping the corners 2.) apply the second coat one angle at a time 3.) used a sanding sponge I bought at Home Depot. The sponge has a sharp 90º edge that makes a very nice and sharp corner. I would suggest wearing cotton gloves when using the sponge. After using one for a day non stop, I had raw fingers.
MikeKy55 is offline   Reply With Quote
Old 07-06-2011, 01:20 PM   #4
Drywall contractor
Agree with MikeKy55. The corner trowels are junk in my opinion. And final sanding with a sponge (go ahead and sand with a pole sander first) will make for a great job. And he's correct about the gloves if you have a lot to sand. I've had my fingers bleeding before after "hand sanding" a big house (300 sheets or more). Years ago when I went to get fingerprinted for a concealed carry permit, the lady asked what kind of work I did because it took 2 or 3 tries to get a decent print of my right thumb, index and third fingers. Years of sanding without gloves had kind of worn them off.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 05:17 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
