Crap! Put A Hole In The Wall! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 01:55 AM   #1
Crap! Put a hole in the wall!
I was drilling in the wall and messed up majorly because it was at the wrong spot, and size. even accidently drilled into the stud. Now I have to fix it before my wife finds out. Any idea on what to do? Help is much appreciated guys.
EDIT: Got some pictures.
Crap! Put a hole in the wall!-20130316_235007.jpg   Crap! Put a hole in the wall!-20130316_234949.jpg   Crap! Put a hole in the wall!-20130316_234925.jpg
Zeus205 is offline   Reply With Quote
Old 03-17-2013, 02:06 AM   #2
Buy some spackle and a putty knife or something to apply it, then try to shape the spackle before it hardens to match the wall texture, maybe using a nail.
Dorado is offline   Reply With Quote
The Following 2 Users Say Thank You to Dorado For This Useful Post:
gregzoll (03-17-2013), Zeus205 (03-17-2013)
Old 03-17-2013, 05:58 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
I have found that spackle and a damp sponge will give you a comparable texture, but the hard part is going to be matching that antique white paint if you have none left over.
Man of many hats
wrangler is offline   Reply With Quote
The Following User Says Thank You to wrangler For This Useful Post:
Old 03-17-2013, 06:03 AM   #4
Afraid of your wife?
Choose a picture that she loves and tape it there. Pick one of the wedding or something and say you just want to be reminded of how lucky you are each and every day. Maybe put the tape under neath so it doesn't look tacky.
She won't want to break your heart and so will leave it there thus buying you time
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
Old 03-17-2013, 08:22 AM   #5
Rewards Points: 125
I had to patch a textured wall, used drywall mud to fill the hole and then pressed a wad of clay on the wall to capture the texture, carefully pressed it on the compound to blend in the patch.Took a little tinkering but worked.
ThatDaveGuy is offline   Reply With Quote
The Following User Says Thank You to ThatDaveGuy For This Useful Post:
Old 03-17-2013, 01:42 PM   #6
haha yeah she was telling me not to do it. Right behind a door so it would look really odd.
So dry wall mud or spackle it is. Thanks guys.
Insulating hole in exterior wall caused by outside electrical outlet panel myboynoy Insulation 4 02-15-2013 08:51 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 09:48 PM
positioning 4" fan hole in brick wall amakarevic Building & Construction 5 05-13-2011 07:50 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
