Cracks In Arches-need Your Opinion - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-24-2014, 11:41 AM   #1
Cracks in Arches-need your opinion
Hi everyone,
I'm new to the site and I need your opinion. There is a house we are considering purchasing in the Charlotte, NC area...it is a 5 year old vinyl-exterior ranch on a slab foundation. The living room, dining room, foyer, and kitchen are all open to each other and arches at every room opening in this large area (probably about 6 archways in this area).
Sounds beautiful, right? Well, the issue I have is that every single arch has a hair-line crack at the corners (most are about 4-5 inches in length). In your opinion, is this a foundation issue or a lousy drywall job? Also, is it possible to fix these cracks or will I just be chasing these cracks forever? If it is a foundation issue, what else should I look for since it is on a slab? Sorry, I don't have pictures.
Thanks so much for your help and opinion!
melswan1 is offline   Reply With Quote
Old 06-24-2014, 12:17 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
It could be either. If there are large cracks in the concrete it is likely structural. I would look below the siding outside and look for large cracks. Some very small cracks are common from shrinkage, expansion and contraction and normal settling. If the cracks in drywall are small straight lines it could be missing tape which is a easy DIY fix.
Robpo is offline   Reply With Quote
Old 06-24-2014, 01:45 PM   #3
Rewards Points: 5,974
Around doorways, windows, and arches are areas prone to small cracks. That is why you should never end a drywall seam at the corner of these areas. No matter what tape and mud you use they will crack over time. If they are just small hairline cracks I wouldn't worry too much about them.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Nailbags (06-25-2014)
Old 07-11-2014, 12:42 PM   #4
Drywall contractor
Rewards Points: 1,070
ToolSeeker is correct, unfortunately. Openings are much more prone to cracking. I would use mesh tape and setting compound to remedy the situation. No guarantees though....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Small cracks in basement foundation letting in water! tw1208 Concrete, Stone & Masonry 10 09-29-2012 12:24 PM
Question Regarding Drywall Cracks Phreek Drywall & Plaster 5 07-26-2012 10:58 AM
Should I be worried about these cracks in the ceiling? LTParis Building & Construction 5 05-09-2012 02:47 PM
Good product to fill cracks in concrete floor wvphysics Flooring 1 10-25-2010 12:49 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 05:23 AM
