Cracks Along Tape Lines - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 02:40 PM   #1
Joe Average
Rewards Points: 22
Cracks along tape lines
Two part question here:
1. I moved into a home 1 year ago that already had a fair amount of cracks in the drywall walls and now there are more. There was also separation of the baseboards and crown molding at the corners. We had a review done of the foundation and they said it was within tolerance. We live in an area with very solid bedrock. Currently I am seeing more cracks, but never jagged, always along the tape lines. Also more separation in the corners as well as sides of stars next to wall. House is 16 years old. Should I be concerned about foundation or is there something else going on here?
2. Should I at some point repair those cracks, what is the best method? I think it is tearing out the old tape, retape, float, and texture. Is that it? Lot of work.
Thanks for the help/ advice.
qualls6 is offline   Reply With Quote
Old 05-04-2013, 02:57 PM   #2
Rewards Points: 5,974
The first thing that came to my mind was wrong tape or wrong mud or just a poor tape job or maybe mixed too much water in their mud. But yes I would say you need to repair if for nothing else but the aesthetics. But from what you have described you really don't need to be in a rush. And you are pretty spot on for the way to repair.
Old 05-04-2013, 03:19 PM   #3
Joe Average
Rewards Points: 22
Thanks for the reply. Wrong tape or mud would not explain the separation at the baseboards and molding. I am sorry to hear that that is the proper way to fix the cracks. Was hoping for an easier way. You're right though, no hurry if it is still cracking.
Old 05-07-2013, 08:33 AM   #4
Rewards Points: 1,426
Just curious what type of temps do you keep your house at during winter/summer? Any idea on humidity levels? If your house gets to extreme in any of those it could cause shrinkage/expansion to the point of cracking. I don't know if this would be contained to the would framing moving and causing cracks or if the compound itself will shrink/expand enough to cause issues.
mikegp is offline   Reply With Quote
Old 05-07-2013, 10:48 AM   #5
Joe Average
Rewards Points: 22
Temp is controlled at all times and pretty moderate. Between 68 and 75. Don't see humidity being an issue. Besides, I wouldn't think temp or humidity swings would cause separation at the baseboards. Crack the caulking maybe but not create a sizable gap.
Old 05-07-2013, 11:25 AM   #6
Rewards Points: 626
I am going to go out on a limb here. Newly built home? If so sounds like the builder used green lumber. That is not equivalnt to eco friendly lumber. it means a moisture content of greater then 19%. The studs are shrinking and curing still. Now that is my assumption. With nothing to go on but what you discribed.
Nailbags is offline   Reply With Quote
Bought 1940 house - Lots of plaster cracks - need help chrisn Drywall & Plaster 2 05-02-2013 07:58 AM
Replacing Duct Tape Used on HVAC Ducts yarrick19 HVAC 5 06-18-2012 12:29 AM
Am I right...teflon tape not needed on new faucet lines? Hossenfeffer Plumbing 2 01-23-2011 02:42 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 05:23 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
