Cracking Drywall Joints - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 06:28 PM   #1
I have drywall joints that crack above my fireplace every winter. When we use the fireplace, the heat makes the crack expand about 1/2 to 3/4 of an inch. Then, in the summer, when we don't use the fireplace, the crack closes up but the paint is still cracked and it looks terrible. I was going to install crown molding to hide the crack, but I'm looking for advice on any other possible way to fix the crack, so it doesn't crack again next winter. I have already made sure the attic is well ventillated and insulated. I know it is from the extreme temperature changes in the wall, but there must be some kind of a solution to deal with the expansion and contraction. Please help!
TLG042 is offline   Reply With Quote
Old 03-23-2010, 12:24 PM   #2
Drywall contractor
Rewards Points: 1,070
The crown may be your best solution, though maybe not entirely perfect. Sounds like the framing lumber is "moving" during the heating/cooling seasons (as it will) causing the cracking. The crown will do the same thing as the drywall to some extent, but it's easier to re-caulk and touch up the trim paint than patch and re-paint the drywall every year.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-07-2010, 03:19 PM   #3
Rewards Points: 150
That is why I recommend metal studs in these type of areas. It also seems that the crack probably forms as two peices of wood separate. Can't suggest anything easy that will keep you from doing touchup every year.
slickgt1 is offline   Reply With Quote
Old 04-08-2010, 12:47 PM   #4
Rewards Points: 150
Seriously? I would look into the framing and installation of that fireplace. That sounds like a lot of movement. I would be concerned that proper clearances were not maintained by your description.
Do you have pictures?
kgphoto is offline   Reply With Quote
Old 04-08-2010, 07:04 PM   #5
Drywall contractor
A truss roof will "move" a lot more than a "stick built" roof also, generally speaking, too...
Old 04-08-2010, 07:09 PM   #6
i agree if its that much movement somethings up behind the drywall
The older I get the better I was
Vertical corner joints cracking in shower stubits Tiling, ceramics, marble 2 02-07-2010 12:46 PM
Tape drywall joints before painting? mcraenz Drywall & Plaster 7 11-19-2009 06:28 PM
cracking drywall dant Drywall & Plaster 1 07-21-2009 12:35 AM
Cracking drywall Smiley77 Drywall & Plaster 4 03-10-2009 04:38 PM
Ceiling drywall cracking and popping sound DoubleM Drywall & Plaster 7 12-17-2008 02:13 PM
