Crack Repair Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 11:02 AM   #1
crack repair help
I tried repairing this crack but it came back. I used the typical taping approach with paper tape. I also suspect I may have a repair on top of a previous repair. The house is almost 40 yrs old so I doubt this is the first time this crack has appheared. What would be the best aproach?
beerdog is offline   Reply With Quote
Old 02-07-2010, 10:46 AM   #2
General Contractor
Cut out the crack with a utility knife. Use mesh tape and hot mud to do the mud work. If you can drive some screws on either side of the crack. You may need to install a 1x board behind the crack if you have access to it for additional support.
ARI001 is offline   Reply With Quote
Old 02-07-2010, 10:55 AM   #3
thats a stress crack on that point load if i'm looking at this right. you may want to cut out that small section of drywall and see how that intersection is fastened
The older I get the better I was
Old 02-07-2010, 12:57 PM   #4
Well, I decided to open it up a little. Turned out the framing arround this area was not super accurate and the drywall was not completly connected to the framing. The crack had also been repaired once before. I built up the framing with 3/4 plywood and pocket screws.
crack repair help-img_0127.jpg   crack repair help-img_0130.jpg   crack repair help-img_0131.jpg
Old 02-07-2010, 05:22 PM   #5
good luck with that use some durabond 90 to bed tape
Old 02-07-2010, 05:33 PM   #6
I used Durabond 45.
Old 02-07-2010, 05:38 PM   #7
good stuff also
Crack in Cast-Iron Wye sonofthetonsured Plumbing 16 01-15-2010 08:10 PM
Pls help! DIY foundation crack repair question tspaulin General DIY Discussions 3 07-16-2009 08:39 AM
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 11:03 AM
Wedge cracks STG Building & Construction 4 07-01-2008 11:41 AM
concrete crack repair summertime General DIY Discussions 2 10-08-2007 03:59 PM
