Crack In Plaster Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 02:25 PM   #1
Crack in plaster ceiling
I recently bought a house that has plaster ceilings. We have a crack in our bedroom that has been there since we moved in. We have a lot of snow and ice on our roof right now, and I think the crack might be getting bigger, although I may just be paranoid!
I am eventually going to have someone come look at it, but in the mean time should I try to tackle the ice on the roof and get it off? Or will this disrupt the crack as I will probably have to use a hammer.
Also should I be concerned about the ceiling caving in? I am a worry wart and always think worst case scenario.
Any help would be appreciated!!
Thank you.
ngintowt is offline   Reply With Quote
Old 02-15-2014, 03:08 PM   #2
Gymschu's Avatar
Rewards Points: 174
You may want to install some PLASTER WASHERS for now to stabilize the area that is cracking. Plaster is brittle, so, yes, pieces of it can let loose from the lathe underneath and come crashing down.
Gymschu is online now   Reply With Quote
Hairline crack in 1950 plaster ceiling comes back nowwhatnapster Drywall & Plaster 8 08-11-2013 11:47 PM
Recurring ceiling crack - Drywall Expansion Joint? kuj0317 Drywall & Plaster 5 11-26-2012 12:27 AM
plaster ceiling repair. patricias Drywall & Plaster 4 04-10-2011 01:35 PM
Is my contractor suggesting the correct way of redoing plaster ceiling? karenldee Building & Construction 7 10-23-2009 11:47 PM
Repairing Ceiling Crack Seam bakerhouse Building & Construction 6 05-05-2008 03:56 PM
