Crack In Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-01-2009, 07:56 AM   #1
crack in drywall
I have re-occuring crack above a doorway in the drywall. I have patched it several times with mud, even cut out a sqaure and patched it that way, but it keeps on cracking. What can I do to remedy this?
mnskor is offline   Reply With Quote
Old 07-01-2009, 11:59 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Are you applying joint tape, or just mudding the crack? Without joint tape it will crack just from normal expansion and contraction.
Old 07-01-2009, 12:58 PM   #3
And be sure to use some Durobond quick setting mud on the tape coat which is much less likely to crack.
Jim Hart is offline   Reply With Quote
Old 07-01-2009, 10:49 PM   #4
I'm using a mesh tape with mud over it. I think it is a 'stress point' which changes seasonally - at least that's what I've been told, but can't seem to fix it.
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Recurring drywall crack? kcrossley2 Drywall & Plaster 2 11-18-2008 09:03 AM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 02:31 AM
Why do drywall joints crack in garages? Weelee929 General DIY Discussions 3 01-06-2006 07:30 AM
