-   -   crack in drywall (http://www.diychatroom.com/f101/crack-drywall-47878/)
mnskor 07-01-2009 07:56 AM
crack in drywall
I have re-occuring crack above a doorway in the drywall. I have patched it several times with mud, even cut out a sqaure and patched it that way, but it keeps on cracking. What can I do to remedy this?
Maintenance 6 07-01-2009 11:59 AM
Are you applying joint tape, or just mudding the crack? Without joint tape it will crack just from normal expansion and contraction.
Jim Hart 07-01-2009 12:58 PM
And be sure to use some Durobond quick setting mud on the tape coat which is much less likely to crack.
mnskor 07-01-2009 10:49 PM
I'm using a mesh tape with mud over it. I think it is a 'stress point' which changes seasonally - at least that's what I've been told, but can't seem to fix it.
