Covering Drywall Screws - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 06:55 PM   #1
Covering drywall screws
Hello,
Does anyone have the same problem that I do?
When I cover drywall screws with mud, I always manage to get air trapped under the mud. (Cue the drywall pros laughter ) No matter how hard I try to push the mud into the screw, the air still bubbles above the surface of the mud. (More laughter )
DIY Hack is offline   Reply With Quote
Old 12-04-2009, 07:03 PM   #2
never had that problem, I pull my knife pretty tight. maybe screws to deep or to much mud or both
Old 12-04-2009, 09:55 PM   #3
PHB Construction LLC
Paulie's Avatar
Don't worry about it, just hit it on the next coat.
Paulie is offline   Reply With Quote
Old 12-28-2009, 06:01 PM   #4
Drywall contractor
Rewards Points: 1,070
Nothing to laugh at. The screws should get 3 coats, so the second and third should take care of the problem if it's just air "bubbles" you're referring to. Often the screws that get "over driven" and break the face paper on the drywall will be the problem. For some reason the mud seems flat when you apply it but after it dries, it protrudes a bit causing a "bump". A quick hit with some light sandpaper will knock the high spot down before the next coat. Any time a screw does break the face paper on the drywall, another should be added that (sinks to the proper depth) to keep the drywall held firmly to the framing member. That will avoid further problems later on (screw "pops"). That's why I always advocate the liberal use of adhesive. It greatly reduces nail/screw pops. And I always nail on wood framing.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-28-2009, 06:33 PM   #5
glue
Old 12-28-2009, 06:38 PM   #6
Drywall contractor
AMEN!! Thanks for the "thumbs-up".
drywall screws handifoot Drywall & Plaster 5 11-16-2009 10:28 AM
What's the trick to get drywall screws all the way in? cody21 Drywall & Plaster 14 08-10-2009 12:05 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
Drywall screws? Fine or coarse, tip for my drill yummy mummy Building & Construction 31 09-27-2007 03:15 PM
