Covered Up Vent - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 10:09 PM   #1
Covered Up Vent
Drywall hangers covered up an H/A ceiling vent, 6x9 in, without cutting a bunch of holes, any easy way to find it? I know the aprox area but not exact location??
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
Old 10-08-2013, 11:44 PM   #2
automated tool pro
Rewards Points: 152
others in your house? if so they should be set at a standard distance from the walls. Find that distance and start cutting
drywallfinisher is offline   Reply With Quote
Old 10-09-2013, 08:09 AM   #3
Rewards Points: 12,790
A simple cheap magnetic nail finder will find out exactly where it is.
There's lots of different styles and makes.
http://www.amazon.com/Stanley-47-400.../dp/B0000BYD3K
Old 10-09-2013, 08:21 AM   #4
Rewards Points: 1,426
Is there an attic above? If yes, go up and drill four holes with a thin bit at each corner of the vent.
You can also crank the heat and use a laser thermometer to find the hot spot.
mikegp is offline   Reply With Quote
plumbing vent boilermaker27 Plumbing 5 09-26-2013 08:37 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
