#1 |
Correct way to drywall around a doorway
Hello, I have been reading about people's drywall cracking around their doors because they installed the drywall wrong.
So, my question is, what is the correct way to drywall around a door frame? I have put up my drywall around my door, but I haven't mudded yet, and I just want to make sure I did it correctly so I don't have any cracks. Thank you Jason |
#2 |
Put a sheet over the opening horizontally(top first) then cut out the opening for the door as opposed to having a small piece of drywall above the door with a vertical seam or two above the door.
Wastes some material but yields the best result. |
#3 |
Average Joe/ex-Navy IC3
A lot of time also, is the wall may be flexing at the drywall, But yeah, not putting any joints at that area is the best result. The same holds true around windows.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#4 |
Learned this here and agree 100%. In fact, I have a vertical crack above my back door on a 9 year old house. I would have been surprised it was there and wondered why had it not been for this site.
#5 |
I have also tried to fix said cracks including an attempt that involved 25 drywall screws, fiberglass tape with setting compound only to have a hairline crack appear a month later.
The door was a hollow 30 inch interior door and opening and closing still caused it.
#6 |
When fixing cracks that are already above the door, would adding more mud and feathering it out further fix the problem? Or would it come back?
I have a crack above a closet door I need to fix. |
#7 |
Too Old
I always keep all drywall joints at least 12" below the header or 12" above the sill. You never want a joint close to something that will settle.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line." |
#8 |
Moderator
Use paper tape and setting type compound this time, JB: “While fiberglass mesh tape is stronger than paper tape in ultimate load, it is more elastic and will
allow visible cracking of the joint compound to occur at lower loads as the glass mesh stretches. Consequently, paper tape will yield the best joint treatment.” From: http://www.usg.com/rc/technical-arti...e-en-J1190.pdf Sounds like you found this out already: http://www.paintsource.net/pages/sol...erfections.htm Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Is tape necessary to repair holes in drywall (in garage)? | Scotch99 | Drywall & Plaster | 4 | 08-22-2011 02:08 PM |
| Repair drywall paper before laying tile? | amybeth25 | Remodeling | 4 | 08-29-2010 06:49 PM |
| Matching new drywall to old textured drywall | pennshaq | Drywall & Plaster | 1 | 05-23-2010 10:30 AM |
| Good ways to run pegboard up to drywall? | upthemaiden | Drywall & Plaster | 1 | 03-09-2009 02:12 PM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
