Correct Use Of Moisture Resistant Purple Board In Bathroom? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 10:16 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can't put Hardi over drywall. (Well I suppose you can) Why would you want to do that? The Hardi is not waterproof and will wick water through to the drywall over time.
I had some reasoning for this, but it's probably faulty.
Yes I'm somewhat sure it is. After all of the above.
Okay Mike, Jaz, I'm out of this one. Take it boys.
XXX
Old 06-16-2011, 11:06 AM   #17
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Scratch, have you seen Bud's blog? I think you might find it very helpful.
http://www.diychatroom.com/blogs/con...wer-walls-152/
Old 06-16-2011, 03:02 PM   #18
Mold!! Let's kill it!
Rewards Points: 2,012
OK. you've got some folks confused. Here is what I think. Do the whole bathroom in moisture resistant drywall. It's a damp area prone to growing mold. MMR board is cheap insurance. Put the 5" piece at the bottom where it is mostly out of sight anyway behind a vanity, tub and toilet. Use Schluter Kerdi membrane in the shower area. Tile over it and forget about it.
Old 06-17-2011, 04:20 PM   #19
Thanks for the link to the blog post. I'm getting there.
fromscratch is offline   Reply With Quote
Old 06-20-2011, 12:18 AM   #20
Registered User
Rewards Points: 4,936
http://publicecodes.citation.com/ico...002_par013.htm
Gary
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 04:25 PM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 10:29 AM
Moisture Barrier behind cement board code? scoot_gt Building & Construction 8 09-29-2007 09:53 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 07:25 PM
