Correct Use Of Moisture Resistant Purple Board In Bathroom? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 06:29 PM   #1
Correct use of moisture resistant Purple board in Bathroom?
I have a small (30sqrft) bathroom that is stripped down to the studs. I was originally going to put up the moisture resistant drywall everywhere but I have an 8.5ft ceiling and can't find the purple board in sizes other than 4X8.
My question, is doing the whole bathroom in moisture resistant drywall overkill anyway, or is this actually the proper way to do it?
If it is overkill I'm tempted to do the walls with 10ft regular sheets and just put the moisture resistant around the tub.
Second question, Can I put a vapor barrier behind the purple board?
(Side question does anyone know where I can find either 54" wide or 10ft long purple board in the CA Bay Area?)
fromscratch is offline   Reply With Quote
Old 06-14-2011, 06:47 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and you don't want to simply seam it because.......................?
XXX
Old 06-14-2011, 06:49 PM   #3
What do you mean by "simply seam it"
I was just thinking with either a 10ft board or a 54" I can keep minimize the joints and keep them all tapered joints.
Old 06-14-2011, 06:52 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I understand but you will still have joints to repair no matter what, so what would be wrong with and extra one or two or three or four joints/seams?
XXX
Old 06-14-2011, 06:56 PM   #5
I've never finished drywall before. And I'm trying to minimize the areas I can screw-up. With an 8.5 ft. ceiling and 4X8 sheets would you make a butt joint down next to the floor?
Old 06-14-2011, 08:46 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NEVER make joints along a door opening. "L"-over.
If it was me (and it isn't)...
I would lay the drywall down holding it about 1/2" to 3/4" up off the floor. Then add a 5" strip above that taper. Then lay-up the second board. You will have to "wide-feather" the single juncture but that's not a big deal I don't think. That way you can get the two seams of the juncture in one pass.
Some of the drywallers around here may disagree but that's what I would do but I have done it a time or two before.
XXX
Old 06-14-2011, 08:55 PM   #7
should I try to recess the 5" strip by either using a thinner sheet for the 5" strip or shimming out the 4ft. sheets?
Old 06-14-2011, 09:57 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Heck no!
No reason to screw around with all of that.
What you will have is basically butt-joints but that isn't a major problem. Spread your joint compound in a wide path and I'm sure you can fix it fine.
XXX
Old 06-14-2011, 10:56 PM   #9
firehawkmph's Avatar
Rewards Points: 1,826
Fs,
Don't worry yourself over taping a butt joint. How do you expect to get good at it if you never try? Patience, not trying to cover everything knee deep in one coat, and using a decent knife or two. It's not that difficult, just takes a little practice. Butt joints just take wider knives. In the time you take trying to find the too easy way out, I'd be done already.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-15-2011, 06:56 PM   #10
So just to back up. I should finish entire bathroom in the purple board?
And on one interior wall I will have tile, Hardibacker, Drywall,... Can I put a vapor behind the drywall?
I'm a bit confused because everything I read says the drywall is not a vapor barrier. But, somehow if I do this tile, hardibacker, drywall, plastic, then I've created a double vapor barrier situation?
thanks
Old 06-15-2011, 06:59 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is this tiled-wall in a shower or is it just a decorative wall in the room?
XXX
Old 06-15-2011, 07:21 PM   #12
tiled shower wall.
(The other 2 walls will just have tile, hardibacker, vapor barrier).
The reason for the drywall on the third wall is that I need the extra furring and the wall is shared with a bedroom so I'm hopeful the drywall will provide alittle bit of sound insulation as well.
Old 06-15-2011, 08:36 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm a bit confused
You think you are confused?
None of your last comment makes any sense. Your shower only has one wall???
In all of your comments you haven't even mentioned a shower until now.
What the heck are you wanting to do?
XXX
Old 06-15-2011, 09:22 PM   #14
Basically putting up walls in the bathroom.
There is a shower-tub area that will be tiled. (3 walls) Two of the walls will get 1/2 hardibacker with a plastic vapor barrier behind.
On the third wall enclosing the tub I was going to fur out the wall with purple drywall and attach either 1/4" or 1/2" hardibacker. I had some reasoning for this, but it's probably faulty.
The question was do I put a plastic vapor barrier behind this tile, hardibacker, drywall amalgamation?
Other than that I'm going to go for the purple board on all walls in the bathroom and just take an extra wide knife to the butt joints.
Old 06-15-2011, 09:43 PM   #15
Sparky
Rewards Points: 510
if you're putting hardibacker over the drywall you shouldnt even need to finish it
Techy is offline   Reply With Quote
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 04:25 PM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 10:29 AM
Moisture Barrier behind cement board code? scoot_gt Building & Construction 8 09-29-2007 09:53 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 07:25 PM
