Correct Order Of Taping And Mudding ? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 03:52 PM   #16
Rewards Points: 153
Correct order of taping and mudding ?
Originally Posted by Jim McC View Post
Thanks. So I can't just use sanding sponges? Or are they more for light duty sanding? I just need to do an 18' X 18' ceiling.
Is wet sanding even a possibility?
You can do the whole thing with sanding sponges.
Wet sanding is a possibility - it very good for occupied homes due to no dust. It helps if you don;t have big lumps and ridges. Chances are you'll still need the 45 angle sanding sponge to get the corners appearing crisp. Also, for lap marks and things like that, you can shave them off before the coat is fully dry by flexing your knife blade into a C shape with two hands, and holding it almost perpendicular to the surface, then drawing it along the lap mark. That can save you a lot of wet or dry sanding.
eandjsdad is offline   Reply With Quote
Taping and mudding cement board jonhayden Drywall & Plaster 12 01-31-2014 09:49 AM
Mudding and taping cocean Drywall & Plaster 4 01-20-2014 01:06 PM
taping and mudding behind shower stall BobLoblaw Drywall & Plaster 5 04-07-2012 04:41 PM
taping and mudding backerboard in a shower kathyll Building & Construction 3 07-09-2011 06:53 PM
