-   -   Correct order of taping and mudding ? (http://www.diychatroom.com/f101/correct-order-taping-mudding-195240/)
Jim McC 02-01-2014 02:16 AM
What is the best order to follow in taping and mudding joints? The walls were already done and painted by a previous owner, so we have:
1) Ceiling with taper and butt joints
2) Inside corner where ceiling and walls meet
3) Soffit with inside and outside corners
Thanks. I'm a beginner, so I want to do this in the best, most efficient way.
oh'mike 02-01-2014 06:39 AM
First---the right muds--
Multipurpose---green lid--contains glue and is used for setting paper--can be used for second fill coat---hard to sand---
powdered easy sand---chemical setting--5-20-45-90 minute setting time--
Very hard to sand---used to fill gaps before taping---as the second fill coat--filling corner bead.
Light Weight--blue lid---topping compound--easy to sand--soft--used for final top coat----
Next--the order of things---I do the corner beads and gap filling first--then the inside corners--then the flat areas---this is not set in stone---the order can be varied.
As a beginner, buy good tools--6"-10"-12" blades--
For tape? I use paper not mesh---inside corners? Consider using Straight Flex---
It is expensive but ,because it is stiff,will five you nice straight corners.
ToolSeeker 02-01-2014 07:30 AM
Sorry I'm a little confused if it's already done and painted why are you mudding and taping? Does this mean the corner bead has already been installed. If it's been taped already you don't need to re-tape.
Sorry re-read the post now I understand.
ToolSeeker 02-01-2014 07:51 AM
OK let me try again since I had my coffee. I would do the angles first, where the ceiling meets the wall, and the soffits, then the tapers then the butts. What you need to be careful of is where these joints intersect, that you don't get a build-up in these areas. Hopefully for your sake there aren't too many butts.
This order isn't written in stone just the way I would probably do it. Just remember when mudding thin coats are better, meaning after you put the mud on you are going to pull almost all of it back off. For instance after the second coat you may still be able to see the tape. And you must let it totally dry between coats.
Jim McC 02-02-2014 01:10 AM
Thanks guys. Do you recommend sandpaper or sanding sponges? What about the 3M sanding sponges? I noticed they are rated as medium, fine, extra fine, etc. I don't have a sanding pole. I'm just going to do it by hand.
oh'mike 02-02-2014 06:44 AM
You need a flat sanding pad--either a hand held or pole mounted one---this will flatten out the work---you also need the 3Msanding sponges---for edges and details--Medium is good----
ToolSeeker 02-02-2014 08:13 AM
If you ever need the heavier duty use sanding screens instead of sandpaper, the paper clogs up to easy.
eandjsdad 02-02-2014 01:39 PM
Buying a pole will be worth it - they're cheap and speed sanding up considerably.
The sanding sponge you want for corners has a 45 degree angle on the edge, medium as already said.
ToolSeeker 02-02-2014 02:11 PM
Have you tried the poles with the round sanding pads. A little more costly but I really like them. Didn't think I would. But yes a pole sander is a must.
Jim McC 02-02-2014 02:41 PM
Thanks. So I can't just use sanding sponges? Or are they more for light duty sanding? I just need to do an 18' X 18' ceiling.
Is wet sanding even a possibility?
Jim McC 02-02-2014 03:14 PM
Mudding questions
When mudding the wall/ceiling intersection, is it easiest for a beginner to use a corner tool, or do one edge, then the other edge the next day?
Outside corner bead - Are both edges done at the same time, or do one edge, then the other edge the next day?
Thanks.
ToolSeeker 02-02-2014 03:32 PM
Thanks.
I have 2 of those corner tools and anybody that wants them can have them. Just a little tip I assume your using either a 5 or 6" knife to do your inside corners. Go ahead and do both sides the same time except for the final coat.
On the corner bead you can do both sides the same day.
eandjsdad 02-02-2014 03:37 PM
I've heard nothing but good things from people who have tried them. My next purchase is going to be a round bottom pan - guys who do a lot of setting compound work say good things about the clean up time with them.
eandjsdad 02-02-2014 03:41 PM
Some people swear by corner trowels, everyone else swears at them. Experience doesn't seem to be the issue.
Bottom line is the most likely outcome for anyone (experienced or inexperienced) using a corner trowel for the first time is a messed up corner.
eandjsdad 02-02-2014 03:42 PM
That sounds like a guy over on CT.
