Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-20-2012, 07:01 PM   #1
corner tool
What do you guys think of the corner tool for inside corners?
jackwashere is offline   Reply With Quote
Old 08-20-2012, 07:11 PM   #2
corner tool
I use one if I have one on hand, but most people I've talked to hate them.
What I do with mine is bend it slightly so it's more then a 90 deg. angle.
What you will find is it's rare to find a true 90 deg. inside corner, by bending it a little I can press down and have it fit tight to both walls.
A 6" wide knife can be just as fast though.
Old 08-20-2012, 07:35 PM   #3
sdsester's Avatar
corner tool
The little ones are worthless. The large, flexible ones can come in handy but you usually have to go back over everything with a wide knife anyhow.
sdsester is offline   Reply With Quote
Old 08-20-2012, 08:09 PM   #4
corner tool
One thing is they dont float the corner out far enough.Should feather out at least 6" out from the corner.
Just do 1 side at a time start with a 6" for first coat than an 8" for second coat.
scottktmrider is offline   Reply With Quote
Old 08-20-2012, 08:19 PM   #5
corner tool
I borrowed one of these to help out my drywaller and it worked great.
http://www.all-wall.com/Categories/C...ll-Trowel.html
Old 08-20-2012, 08:31 PM   #6
corner tool
Its nice especially skim coating, One swipe sets the corner and your just feathering out the edges.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-20-2012, 10:10 PM   #7
corner tool
well. i am glad i didn't buy one yet, then. i am fearing doing my mudding.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Metal corner bead question Firehawk734 Drywall & Plaster 15 06-12-2011 03:49 PM
Corner bead an inside corner? Firehawk734 Drywall & Plaster 2 05-28-2011 12:56 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
