Corner Of Drywall And Tile -- J-bead? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 10:48 PM   #1
Rewards Points: 1,062
corner of drywall and tile -- J-bead?
Should i put j-bead here where drywall will meet tile (where is currently cement board)?
Old 05-08-2012, 10:50 PM   #2
Rewards Points: 13,732
A reguler dry wall outside corner will work.
Old 05-08-2012, 10:54 PM   #3
Question
thanks. which kind do you recommend for bathroom applications, plastic or metal? dunno if metal is aluminum or has steel, cause the latter can rust
Old 05-08-2012, 10:59 PM   #4
Both will work because it's getting covered and painted.
If you want to be safe use plastic.
amakarevic (05-08-2012)
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 6 11-27-2013 09:56 AM
Drywall Corner Beads and tile Auctioneer Drywall & Plaster 2 01-07-2012 05:28 PM
Assistance with tile layout / transition between cement board and drywall JeffreyMCooper Tiling, ceramics, marble 4 08-20-2011 11:47 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
